Error Message
Title: Error in Legends.Show at 1199Stop: A(n) Layout object does not recognize request GetThemes
Cause
The Custom Legend tool cannot distinguish between a view and a layout if they share the same name.
Solution or Workaround
Assign each document in the project a unique name.
Summary:
You can change document names using the Properties dialog box.
Procedure:
- To rename a View document:
1. Click View > Properties
2. Type a new name in the Name field.
3. Click OK - To rename a Table document:
1. Click Table > Properties
2. Type a new name in the Title field.
3. Click OK - To rename a Chart document:
1. Click Chart> Properties
3. Click OK - To rename a Layout document:
1. Click Layout > Properties
3. Click OK - To rename a Script document:
1. Click Script > Properties
2. Enter a new name in the Name field.
3. Click OK
