ERROR
An error occurred while running Define Projection Wizard(coverages, grids, tins); Unloading the tool.
Error Message
When defining a coordinate system for a tin, using the Define Projection Wizard(coverages, grids, tins), selecting one of the following projections produces an error message:
· Cylindrical Equal-Area
· Transverse Mercator
· Polar
The error message is:
"An error occurred while running Define Projection Wizard(coverages, grids, tins). Unloading the tool."
Cause
This is a known issue.
Solution or Workaround
Use the PROJECTDEFINE command in Workstation ArcInfo to set the projection information for the tin.
Article ID:000004200
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
