ERROR
Attempts to change the style of a vector tile layer in ArcGIS Online Map Viewer Classic, or ArcGIS Vector Tile Style Editor fail, and return the following error message:
Error: An error occurred while getting sprite data.
When adding the vector tile layer to ArcGIS Pro, a red exclamation mark is displayed next to the layer in the Contents pane.
The sprite parameter in the vector tile style layer's JSON file is pointing to an invalid item path.
To resolve the issue, modify the sprite item path in the vector tile style layer's JSON file.
."sprite": ""../sprites/sprite","glyphs",
 button. Click View item details.
Note: If necessary, use ArcGIS Vector Tile Style Editor to add, edit, and save the desired sprite. Refer to Vector Tile Style documentation: Sprite Editor for more information.
Article ID: 000026740
Get help from ArcGIS experts
Start chatting now
