ERROR
An error occurred while creating the printed map
First Published: January 30, 2018
Error Message
Printing a web map from the map viewer in ArcGIS Online fails with the following error returned:
Error:
An error occurred while creating the printed map.
Screenshot of the error message
Cause
  • The web map contains a layer that is a secured ArcGIS Server service.
  • The web map uses HTTP, while the organization using the print service in ArcGIS Online allows access to the organization through HTTPS only.
  • A large number of feature layers or feature services in the web map exceeds the 10MB print size limit.
Solution or Workaround
Depending on the cause, select one of the options below to resolve this issue:
Use the ArcGIS Server PrintingTools utility service in ArcGIS Online
Only administrators can configure the site's utility services in ArcGIS Online. For more information, refer to ArcGIS Online: Configure utility services.
  1. Open the ArcGIS Server REST page and under Folders, click Utilities > Utilities/ PrintingTools (GPServer).
  2. In the Utilities/ PrintingTools (GPServer) page, under Tasks: click Export Web Map Task.
  3. Copy the URL of the Task: Export Web Map Task in the address bar.
  4. In ArcGIS Online, paste the URL into the Printing text box in the Utility Services tab. For more information, refer to ArcGIS Online: Printing.
  5. Open the web map in ArcGIS Online, and print the web map.
Use HTTPS in the URL of the web map instead of HTTP and print the web map
If the web map is not configured to use HTTPS, refer to ArcGIS Server: Secure ArcGIS Server communication.
Remove unrelated feature layers or feature services from the web map or use hosted tile layers and print the web map
For more information, refer to ArcGIS Online: Publish hosted tile layers from hosted features and ArcGIS Online: Publish hosted tile layers from files.
Article ID: 000017602
Software:
  • ArcGIS Online
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
