ERROR
All licenses are in use
First Published: May 5, 2016
Error Message
When launching ArcMap, the following error message is displayed:
Error:
All licenses are in use.
Cause
This error message is displayed if the License Server Administrator is being used or is not available to be used. In some instances, this error also occurs when other client machines return the borrowed license, but the return is not reflected in the License Server Administrator.
Solution or Workaround
Restart or refresh the License Server Administrator using one of the options below, and restart ArcMap.
Re-read the licenses
  1. Click Start > Programs > ArcGIS > License Manager > License Server Administrator.
  2. Navigate to the Start/Stop License Service folder.
  3. Click the Stop button to stop the license manager.
  4. Click the Start button to start the license manager.
  5. Click the Re-read Licenses button, and click OK.
The Start/Stop License Service folder in ArcGIS License Server Administrator
Restarting the license server overwrites existing data in the debug log.
Refresh license availability
  2. Navigate to the Availability folder.
  3. Click the Refresh button, and click OK.
The Availability folder in ArcGIS License Server Administrator
Check to see if ArcMap is running on another machine
  3. Click View License Usage > Checked Out.
The View License Usage button in ArcGIS License Server Administrator
  1. Select a product type in the Select a feature dropdown menu.
The Checked Out tab in ArcGIS License Server Administrator
  1. A list of all machines currently using licenses for the selected product is shown. To revoke a license, select a machine and click Force Check-In. Alternatively, go to the designated client machine and close ArcMap.
The Force Check-In button in ArcGIS License Server Administrator
Article ID: 000012069
Software:
  • ArcMap
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
