PROBLEM
Error Administering Service in ArcIMS 4.0.1 when the AXL file contains an image directory
You may have encountered a known issue with ArcIMS 4.0.1 under these very specific circumstances.
1. When you tried adding a new ImageServer service, you received an "Error Administering Service" message.
AND
2. Your map configuration file contains a reference to an image directory.
The problem described in this article is specific to ArcIMS 4.0.1 only.
Cause
The "Error Administering Service" message can have many potential causes and in many cases indicates a problem the ArcIMS Spatial Server is having with the data being referenced in the map configuration file.
Solution or Workaround
See the link in the Related Information section for more details and to download a patch for ArcIMS 4.0.1.
    Article ID:000006092
    Software:
    • Legacy Products
    Download the Esri Support App
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Go to download options
