ERROR
Additional non-parsable characters are at the end of the string
Error Message
When configuring ArcGIS Web Adaptor in a browser, the following error is returned:
Error:
Additional non-parsable characters are at the end of the string.
Error message
Cause
This error occurs due to the following known causes:
  • Connection to Web Adaptor not properly configured
    Connections to the Web Adaptor are not properly configured during the installation or are changed since the installation.
  • Browser limitations
    Depending on the version of ArcGIS Web Adaptor installed, the Web Adaptor conflicts with the browser's security settings.
Solution or Workaround
Use one of the following solutions depending on the cause of error:
    Ensure the Web Adaptor is configured accordingly, mainly the Web Adaptor URL, the Web Context URL, authentication settings, or firewall settings. Refer to the Related Information section for more references.
    Configure the Web Adaptor in a different browser or disable the browser's security settings before configuring the Web Adaptor.
Alternatively, configure the Web Adaptor with the command line. Refer to ArcGIS Enterprise: Configuring the Web Adaptor from the command line for more information.
Article ID: 000021957
Software:
  • ArcGIS Web Adaptor
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
