ERROR
Add Field Failed: Cannot create a table with a duplicate column
Error Message
When adding a field to an attribute table, the following error may occur:"Failed to add the field to the table/feature class. Cannot create a table with a duplicate column."
Cause
A field in the attribute table already has the same name.
Solution or Workaround
Rename one of the duplicated fields or delete the old field.
Article ID:000006322
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
