ERROR
ACCESS server encountered a segment violation
Error Message
This error occurs when running DBMSEXECUTE or DBMSCURSOR on an Access table:"ACCESS server encountered a segment violation"
Cause
The Access table contains column types that ArcInfo cannot interpret, such as Memo, OLE Object, and Hyperlink.
Solution or Workaround
Try one of the following:
  • Remove the offending fields from the table you are querying.
  • Create a query that doesn't include these fields.
Article ID:000003685
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
