ERROR
A Runtime Error has occurred. Do you wish to Debug?
Error Message
When trying to open an ArcToolbox tool or open the Environments on the Tools > Options > Geoprocessing tab, the following or similar error message(s) is displayed:"A Runtime Error has occurred.
Do you wish to Debug?Line: 217
Error: Syntax error"
Cause
One possibility is that one or more MS XML .dll files are not properly registered.
Solution or Workaround
Manually re-register the msxml.dll, msxml2.dll and msxml3.dll.
  1. Navigate to Start > Run, type cmd and click OK.
  2. Type the following and press enter:
    Code:
    cd c:\windows\system32
  3. Type the following and press enter:
    Code:
    regsvr32 msxml.dll
  4. Type the following and press enter:
    Code:
    regsvr32 msxml2.dll
  5. Type the following and press enter:
    Code:
    regsvr32 msxml3.dll
Article ID:000010340
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
