ERROR
8417: No record found.
Error Message
When authorizing ArcGIS Desktop or ArcGIS Pro, the following error is returned:
Error:
Cause
The following are the known causes for this error:
  • The authorization number is invalid
    The authorization number for ArcGIS Desktop or ArcGIS Pro is incorrect or has expired.
  • The license version is incorrect
    The license to authorize ArcGIS Desktop or ArcGIS Pro is of a different version. For example, using a version 10.0 license to authorize ArcGIS Desktop version 10.1 and above triggers the error.
Solution or Workaround
Depending on the cause, use one of the following solutions:
  1. The authorization number is invalid
    Check the correct authorization number in My Esri or renew the license if it has already expired.
    Follow the steps below to check the authorization number:
    1. Log in to My Esri.
    2. Click My Organizations > Licensing.
    3. Click View Authorizations.
    4. Click the license. The authorization code can be viewed under the Authorization Number column.
The authorization number column of an individual license in My Esri
If the authorization number is correct and the error reoccurs, contact Esri Support Services  for a new authorization number.
  1. The license version is incorrect
    Ensure that the correct version of the license is used according to the version of ArcGIS Desktop or ArcGIS Pro being authorized. The license version can be checked at My Esri.
    Follow the steps below to check the license version:
    3. Click View Authorizations to see the version of the license.
The license version highlighted in the licensing tab of My Esri
Article ID: 000022549
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
