ERROR
502 Web server received an invalid response while acting as a gateway or proxy server
Error Message
Accessing a web server with not trusted or expired Portal for ArcGIS and/or ArcGIS Server self-signed certificates returns the following error, even if the web server certificate is valid.
Error:
Error: 502 Web server received an invalid response while acting as a gateway or proxy server
Cause
A certificate is a digital file that contains information about the identity of the web server. It also contains the encryption technique to use when establishing a secure channel between the web server and the organization. See: Enable HTTPS on your web server
Despite a valid Secure Sockets Layer (SSL) certificate on the web server, the error is returned because the Portal for ArcGIS and ArcGIS Server self-signed certificates have expired.
There are no web adaptors in an Azure Web Geographical Information Systems Cloud Builder deployment. Instead, a URL Rewrite is used, redirecting from a web server URL to HTTPS port 7443 for Portal for ArcGIS, and HTTPS port 6443 for ArcGIS Server.
Solution or Workaround
To circumvent the error, follow the steps below:
  1. Export the self-signed certificates from Portal for ArcGIS and ArcGIS Server.
  2. Install these certificates to the server's trusted storage.
  3. Switch Portal for ArcGIS and ArcGIS Server to use their self-signed certificates.
Article ID: 000017820
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
