ERROR
5004: SpatialQuery.whereClause is not a valid SQL WHERE clause
Error Message
The ArcWeb Services product line has been retired. ESRI recommends that customers who wish to create Web applications or use services similar to those that were available in ArcWeb Services transition to the capabilities of ArcGIS Server and ArcGIS Online.
The following error message occurs even though the WHERE clause, which is very long, appears to be valid.
v2006.1:
"5004: not a valid SQL where clause or invalid fields used in the where clause."
v2006:
"5004: SpatialQuery.whereClause is not a valid SQL where clause Or Invalid fields used in the where clause."
v2:
"5004: ProximityOptions.whereClause is not a valid SQL where clause Or Invalid fields used in the where clause. "
Cause
The WHERE clause contains too many items. For example the IN statement can only hold 1000 values.
Code:
variable IN ( value1, value2, ... valueN)
Solution or Workaround
Split the IN clause into sets of 1,000-value IN clauses and put them together with the OR command:
Code:
variable IN (value1, value2, ... , value1000) OR variable IN (value1001, value1002, ... , value2000) OR variable IN (value2001, value2002, ... , value2345)
Article ID:000007617
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
