ERROR
ERROR<39170> - Auto-Upgrade - conn=-1 op=-1 msgId=-1 - Configuration error Phase 1/2 of the data upgrade has failed
First Published: May 5, 2016
Error Message
A startup process failure on ArcGIS for Server returns the following error message in the ldap.log file:
"ERROR<39170> - Auto-Upgrade - conn=-1 op=-1 msgId=-1 - Configuration error Phase 1/2 of the data upgrade has failed. Please refer to the error log or output for more information. Server not running!! Failed to start ns-slapd process."
Cause
The error is caused by a missing dse.ldif file. This file is a Directory Server configuration file that is read once during startup. The file can go missing at times due to an improper shutdown of the server.
Solution or Workaround
Replace the missing file with a backup copy located in the 'config' folder.
  1. Locate the backup file in the following directory:
    • <ARCGIS_INSTALL>/servercore/agsidsvr/agsldap/slapd-appd20/config/
  2. Make a copy of the backup file 'dse.ldif.bak' and rename the copy to 'dse.ldif'.
  3. Restart the machine.
Article ID: 000012045
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
