ERROR
Error 1904. Module C:\WINDOWS\system32\RegObj.dll failed to register. HRESULT -2147024770
Last Published: February 13, 2024
Error Message
When installing ArcGIS Desktop or one of its service packs, the following error is encountered:
"Error 1904.
HRESULT -2147024770."
Cause
1904 errors can have many causes. The most common cause for this error appearing on module RegObj.dll is that an anti-virus program has removed the file.
Solution or Workaround
Follow the steps in the "Windows Installer appears when starting ArcMap" article, located in the Related Information below, to eliminate this error.
If that does not fix the problem, follow the links in the Error 1904 Index, also linked below, for further suggestions.
    Article ID: 000009972
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
