ERROR
ERROR 160619: Cannot enable archiving on non-simple dataset
Last Published: August 28, 2024
Error Message
When attempting to enable Archiving on a feature dataset that contains a topology, an error is encountered:
"EnableArchiving: ERROR 160619: Cannot enable archiving on non simple dataset."
The image below of the Feature Dataset Properties is an example of this error.
Cause
Topology is an example of non-simple data. Enabling archiving on a non-versioned feature dataset that contains a topology is not supported by the software.
Solution or Workaround
Non-simple data (geometric network, topology, or network dataset) must first be registered as versioned to enable archiving.
Article ID: 000030800
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
