ERROR
When using these commands or applications:
· COV2SDE
· SHP2SDE
· ArcCatalog
· ArcView
· Map Objects
· Third pary applicationsThis error occurs, though XY offset and scale are valid:(-139) 'Coordinate out of bounds'Message example:ESRI SDE: Coverage to Layer Loading Utility Tue Nov 9 07:48:18 1999
Loading feature class/subclass "anno.roadname"
from Coverage "/gisdata/libpcl/source/d138/d13818/parcel"
sde_layer_roadname is in LOADONLY mode
SDE Error(-139) The specified coordinate exceeds the valid coordinate range
Error inserting record 37 into layer
Error inserting record 38 into layer
The error applies to X, Y, Z and M coordinates that exceed the minimum and maximum ranges. The Z and M coordinates have their own offset and scale values.
Check M and Z extents to ensure your values for individual features are valid.
Article ID:000002326
Get help from ArcGIS experts
Download the Esri Support App
