PROBLEM
During a client installation of ArcGIS Server, ArcGIS Engine Developer Kit or ArcGIS Server Java ADF from an admin location, the following error message is displayed:
"Error 1309 - Error reading from file <path to file is provided>."
When performing an admin installation of ArcGIS Server, ArcGIS Engine Developer Kit or ArcGIS Server Java ADF, you cannot install to a directory structure that contains more than 28 characters (including the \). Some of the Java samples are located in a directory structure that would exceed the Windows 256 character limit. If the Windows character limit is exceeded, file names will be truncated. When a client performs an installation from this admin location, or a service pack is applied to this admin location the installation will error because it cannot find the correct file (because the file name has been truncated).
Get help from ArcGIS experts
Download the Esri Support App
