ERROR
An unexpected error occurred during tool execution
First Published: May 13, 2026
Last Published: May 13, 2026
Error Message
During the creation of a route layer in ArcGIS Pro and its subsequent publication to ArcGIS Enterprise, the software does not allow the route layer to be published. After a certain amount of time, it remains loading with no response until it finally returns Error 030206, "An unexpected error occurred during tool execution", as shown in the image below.
Cause
This is because the Spatial Analysis tools are stopped in ArcGIS Server Manager; these are required to run this type of task in ArcGIS Pro. When these tools are stopped, it is not possible to publish any type of task from ArcGIS Pro to ArcGIS Enterprise.
Solution or Workaround
Follow the steps below to activate the geoprocessing service from ArcGIS Server Manager:
  1. Go to the URL for the Spatial Analysis Tools service to verify that the service is running:
https://yourdomain/webadaptor/rest/services/System/SpatialAnalysisTools/GPServer
  • If the service is not running, it returns the following message:
"Error: Service System/SpatialAnalysis/GPServer not started Code: 500".
Confirming that the Spatial Analysis Tools service is not running in ArcGIS Server Manager
  1. Once you have verified that the service is not running, go to your ArcGIS Server Manager URL.
  2. Click the Services tab.
  3. On the left side, click the System folder.
  4. In the search bar, type Spatial Analysis Tools.
  5. Click the Play icon in the top right corner to start the service.
starting the service in ArcGIS Server Manager
  • This starts the service, and a message is returned indicating that the service is running successfully.
ArcGIS Server Manager indictes that the service has started
  • Once this is done, the route layer can be successfully published from ArcGIS Pro to ArcGIS Enterprise.
confirming the route layer is published in portal
Article ID: 000039402
Software:
  • ArcGIS Pro
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
