ERROR
ERROR 010096: There is no Spatial Analyst license currently available or enabled
First Published: February 4, 2019
Error Message
Using a Spatial Analyst tool, such as 'Hillshade', returns a Tool Not Licensed dialog box with the following error message:
Unable to execute the selected tool.
You do not have the necessary license to execute the selected tool.
ERROR 010096: There is no Spatial Analyst license currently available or enabled.
The error message when using the Spatial Analyst tool without a license.
Cause
  • The Spatial Analyst extension is not authorized.
  • The Spatial Analyst extension is not enabled in ArcMap.
  • The Spatial Analyst extension is not enabled in ArcCatalog.
Solution or Workaround
Perform the solutions below in the order they are presented.
These solutions assume the Spatial Analyst license has been purchased, but not enabled. Refer to ArcGIS Spatial Analyst for more information.
Verify that the Spatial Analyst extension is authorized
  1. Navigate to Start > All Programs > ArcGIS. Launch ArcGIS Administrator.
  2. Click Availability in the left pane.
  3. Ensure the extension is authorized for Single Use licenses, or Available for Concurrent Use licenses. If the licenses are not authorized, refer to ArcMap: Authorizing your software for more information.
The Spatial Analyst license is authorized for Single Use licenses in the Availability folder in ArcGIS Administrator
The Spatial Analyst license is available for Concurrent Use licenses in the Availability folder in ArcGIS Administrator
Enable the extension in ArcMap
  1. Launch ArcMap.
  2. Navigate to Customize > Extensions, and check the Spatial Analyst checkbox. This enables the extension in ArcMap.
Enable the extension in ArcCatalog
  1. Launch ArcCatalog.
  2. Navigate to Customize > Extensions, and check the Spatial Analyst checkbox. This enables the extension in ArcCatalog.
Certain functionalities in ArcMap, such as ModelBuilder, require the extension enabled in ArcCatalog.
Article ID: 000020013
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
