ERROR
When running the Enable Enterprise Geodatabase geoprocessing tool in ArcGIS Pro against a Microsoft SQL Server database, the tool fails and returns the following error:
Error 00837: The workspace is not the correct workspace type
This error occurs when the target Microsoft SQL Server database does not have Read Committed Snapshot Isolation (RCSI) enabled. ArcGIS Pro requires RCSI to be enabled on the SQL Server database prior to initializing geodatabase system tables and converting the database into an enterprise geodatabase.
To resolve this issue, enable the READ_COMMITTED_SNAPSHOT setting in SQL Server using Microsoft SQL Server Management Studio (SSMS) before re-running the tool.
sa or the database administrator account).<Database_Name> with the name of your target database:ALTER DATABASE <Database_Name> SET READ_COMMITTED_SNAPSHOT ON; GO
Article ID: 000043407
Get help from ArcGIS experts
Start chatting now
