ERROR
001732: Could not copy data from Runtime Geodatabase <value> to File Geodatabase <value>
Error Message
Attempting to run the Copy Runtime Geodatabase to File Geodatabase (Conversion) tool in ArcGIS Desktop fails and returns the following error:
Error:
Cause
This error may be due to the following possible causes:
  • The license used is a Basic license, and the geodatabase contains attachments. Standard or Advanced licensing is required for attachments to be added. To learn more about adding attachments, refer to the following web help document, ArcGIS for Desktop: Adding attachments to features.
  • The runtime geodatabase residing in an SQLite geodatabase is topologically incorrect.
Solution or Workaround
Use one of the following solutions to solve the issue according to the cause:
  • Remove the attachments from the geodatabase if using a Basic license is a must, or upgrade to the Standard or Advanced license. For more information about removing attachments, refer to the following web help document: ArcGIS for Desktop: Remove Attachments
  • Identify, fix, and validate the topology to prevent the error. For more information about fixing topology errors, refer to the following web help document: ArcGIS for Desktop: Fixing topology errors
Article ID:000015006
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
