ERROR
ERROR 001248 This Geodatabase is not supported. Please upgrade your Geodatabase when using the Prune Branch History tool
First Published: September 23, 2025
Last Published: October 2, 2025
Error Message
The Prune Branch History tool, introduced in ArcGIS Pro 3.5, is a new feature designed to help users manage and clean up the historical records of branch versioned datasets. This tool allows you to delete outdated, retired records—freeing up storage and improving data efficiency without compromising essential information.
Error Messages
While using the Prune Branch History geoprocessing tool, you may encounter one of the following error messages indicating that a stored procedure is missing or that an upgrade is necessary.
ERROR 001248: This Geodatabase is not supported. Please upgrade your Geodatabase to 13.5 or higher.
Failed to execute (PruneBranchHistory).
Prune Branch History geoprocessing tool Error 001248 message
ERROR 161019: Function or procedure does not exist [[Microsoft]
[ODBC Driver 17 for SQL Server][SQL Server]Could not find stored
procedure 'sde.SDE_branch_modified_clean_no_date_match'.]
[SOR_CLPUN.ARCFMUN.TX_LOAD_READING]
Prune Branch History geoprocessing tool Error 161019 message
Cause
Version Dependency
The Prune Branch History tool has a dependency that requires the stored procedure sde_branch_modified_clean_no_date_match.  This stored procedure was introduced to all database platforms in version 3.4 and backported to earlier versions via patches, however, compatibility varies by platform.
Compatible Versions
The following versions of the Enterprise geodatabase are supported with the Prune Branch History geoprocessing tool. The specific versions listed represent the minimum version supported for each major release of ArcGIS Pro and ArcGIS Enterprise; newer minor versions are also supported. All newer major versions higher than 3.4 are also supported unless otherwise specified.
Oracle
  • 3.5 or newer
SQL Server, PostgreSQL, Db2
  • 3.4 or newer
  • 3.3.2
  • 3.2.4
  • 3.1.7
  • 11.3 Patch 1
  • 11.1 Patch 3
  • 10.9.1 Patch 7
  • 10.8.1 Patch 12
SAP HANA
  • 3.4 or newer
  • 3.3.3
  • 3.2.4
  • 3.1.8
  • 11.3 Patch 1
  • 11.1 Patch 3
  • 10.9.1 Patch 7
  • 10.8.1 Patch 12
Solution or Workaround
Upgrade your geodatabase
If you receive error messages similar to those shown in the images above while using the Prune Branch History tool, it is recommended to upgrade your geodatabase to one of the compatible versions listed above or higher, for your specific DBMS platform.
Learn more about ArcGIS Pro releases and patches.
For more information about geodatabase upgrades, see the following upgrade topics for the type of geodatabase you are using:
Geodatabases in Db2
Upgrade a geodatabase in Db2
Geodatabases in Oracle
Upgrade a geodatabase in Oracle
Geodatabases in PostgreSQL
Upgrade a geodatabase in PostgreSQL
Geodatabases in SAP HANA
Upgrade a geodatabase in SAP HANA
Geodatabases in SQL Server
Upgrade a geodatabase in SQL Server
Article ID: 000038223
Software:
  • ArcGIS Pro
  • ArcGIS Enterprise
  • ArcGIS Utility Network
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
