ERROR
Error 000732 Input Address Locator: Dataset\GIS Servers\arcgis on tasks.arcgisonline.comlocators\Locators\ .GeocodeServer does not exist
Error Message
When using one of the ArcGIS Online address locator tasks in the Geocode Addresses tool in ArcToolbox, the following error is returned:
Error 000732
Input Address Locator: Dataset\GIS Servers\arcgis on tasks.arcgisonline.comlocators\Locators\<locator name>.GeocodeServer does not exist or is not supported.
Cause
The Geocode Addresses tool does not recognize composite locators being served with ArcGIS Server.
Solution or Workaround
Make sure that you are not connected to the ArcGIS Online server connection or are not using it before proceeding with the following steps.
  1. Rename the ArcGIS Server connection under GIS Servers to "arcgisonline" in ArcCatalog.
    A. Right-click the ArcGIS Server connection.
    B. Click Rename.
  2. If applicable, rename the corresponding connection file under %USERPROFILE%\Application Data\ESRI\ArcCatalog to "arcgisonline.ags".
Article ID: 000010565
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
