ERROR
ERROR 000539: File "<expression>", line 1, SyntaxError: invalid token
Last Published: February 23, 2022
Error Message
When creating a model with the ModelBuilder function in ArcGIS Pro using the Calculate Field tool and the output value of the Iterate Feature Selection iterator connected as an expression, the following error message is returned.
Error:
ERROR 000539: File "<expression>", line 1 SyntaxError: invalid token
Error 000539
Cause
The error occurs because the output value of the iterator is used as an expression rather than an inline variable in the Calculate Field tool.
The tool has two outputs: Selected Features and group Value of the field for selected features, which could be used as an inline variable in other tools. Refer to ArcGIS Pro: Inline variable substitution for more information.
Solution or Workaround
To resolve the issue, define the Value of the Iterate Feature Selection as a Precondition of the Calculate Field tool and set it as an inline variable for calculating the field.
  1. Remove the connection between Value and Calculate Field.
  1. Make a new connection by dragging the arrow from Value to Calculate Field.
  2. Select Precondition. Notice the connected arrow is dotted.
Make a new connection Notice the connection line is dotted
  1. On the ribbon, in the ModelBuilder tab, click Run.
In the ModelBuilder tab, click Run
The image below shows the ModelBuilder function runs successfully.
The ModelBuilder function runs successfully
Article ID: 000027064
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
