ERROR
When attempting to copy a feature class with a custom coordinate system from a file geodatabase to a PostgreSQL enterprise geodatabase hosted on Amazon RDS, the process fails with the following error:
Error Error 000260: The SE_SPATIALREFINFO object was not initialized.
This error occurs because Amazon RDS does not support the installation of the ST_Geometry library required by ArcGIS. Instead, RDS uses PostGIS as the spatial type. Feature classes with a custom coordinate system are not fully compatible with this setup, which causes the copy process to fail.
To work around the error and successfully transfer the data, follow these steps.
Article ID: 000038853
Get help from ArcGIS experts
Start chatting now
