ERROR
Error 000224 Cannot insert features - Limit for 'Max# of ordinates in the SDO_ORDINATES varray has been reached
First Published: March 28, 2024
Last Published: November 17, 2025
Error Message
When copying a feature class containing features with a high number of vertices into an Oracle Enterprise geodatabase and storing the data using SDO_Geometry as the spatial storage type, the following error is returned, as shown in the image below:
Error 000224: Cannot insert features - Limit for 'Max# of ordinates in the SDO_ORDINATES varray has been reached [OCI-22165: given index [1048576] must be in the range of [0] to [1048575]
Cause
The maximum SDO_ORDINATE_ARRAY size in Oracle is 1,048,576 and the data being copied into the geodatabase using SDO geometry exceeds the limit. For 2D data, there can be (1048576 - 1)/2 (about 524,287) vertices in a single SDO_GEOMETRY.
Solution or Workaround
On the Oracle database server, there is a script located at Windows: @%ORACLE_HOME%\md\admin\sdoupggeom.sql that can be used to increase the size of ordinate arrays to support very large geometries. More details on running the script can be found in the article Increasing the Size of Ordinate Arrays to Support Very Large Geometries. The script increases the VARRAY limit from 1048576 to 10000000, as shown below:
alter type mdsys.sdo_ordinate_array modify limit 10000000 cascade;
Article ID: 000032169
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
