ERROR
During the initial tests, after completing the ArcIMS Post Installation process, where a network share is created for a distributed environment, for example, using the ArcIMS Configuration option to create a network share to support multiple spatial servers, one of the two following error messages is displayed:
"Windows cannot find '//<Server_Name>/ArcIMS/Output'. Make suer you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search".
-or-
"Unable to display MapService [ERR0922] Output directory not found or not writable".
There are multiple causes for this error.
A. The User Account the spatial server runs under may not have been granted WRITE or FULL CONTROL rights to the \\<Server_Name>\ArcIMS shared directory.
B. The shared drive may be referenced by a drive letter (T:\ArcIMS), instead of in the UNC format \\<Server_Name>\ArcIMS.
Cause B can be resolved by replacing all references to the shared drive letter with its UNC share name.
The account used to run ArcIMS and th spatial servers can be a Domain Account or a Local Account with the same name and password on each server.
Code:
C:\ArcIMS>net share
Share name Resource Remark
ArcIMS C:\ArcIMS ArcIMS Website/Output Shared Folder
The command completed successfully.
Article ID:000008414
Get help from ArcGIS experts
Download the Esri Support App
