ERROR
ArcIMS ArcMap service creation on Solaris fails with the following error logged to the ArcMap server log:
"[ERR0526] HRESULT description: Unable to open the access token of the current thread".
If the map document used in service creation contains a large number of file-based data, such as hundreds of TIFF imagery, then the most likely cause of this failure is due to the ArcMap server process exceeding the file descriptor limitation set in that system. This is a known limitation.
Article ID:000009662
Get help from ArcGIS experts
Download the Esri Support App
