PROBLEM
Enrich Layer can fail for large processing jobs
First Published: February 23, 2023
Last Published: February 23, 2023
When using the ArcGIS Business Analyst Pro Enrich Layer geoprocessing tool, large processing jobs can fail using non-US local datasets. An example of a large processing scenario could be: Enriching 150-mile trade area rings with demographic variables.
Cause
In ArcGIS Pro 3.1, Enrich Layer performance optimizations implemented for the Block Apportionment data retrieval method will cause the Centroids in Polygon method to fail. Block Apportionment is used for smaller geographies.
For example, to determine the population in five-minute drive time trade areas in a city. Centroids in Polygon captures the centers of geographies typically at larger analysis levels, such as determining population at regional or national scales.
Solution or Workaround
Apply one of the following options in the Enrich Layer > Environments tab, then run the tool:
  • Set the Parallel Processing Factor to "1"
  • Check Use Detailed Aggregation
Article ID: 000029722
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
