HOW TO
Enable legacy upload/download for Business Analyst Server
First Published: March 31, 2017
Summary
Starting at Business Analyst 10.5, there is new functionality available to publish a project to Portal for ArcGIS. Moreover, in previous versions, users were able to upload and download content from Business Analyst on a desktop machine to Business Analyst Server.
The instructions provided below describe the steps to enable the previous upload and download functions of Business Analyst Server, as well as to enable the new Publish Project functionality.
Procedure
  1. If necessary, close Business Analyst.
  2. Open the Windows Registry Editor.
  3. Navigate to HKEY_CURRENT_USER\SOFTWARE\ESRI\BusinessAnalyst\.
  4. Highlight the GlobalProperties folder.
  5. Right-click in the right pane of the Registry Editor window, and click New > String Value.
  6. Edit the name of the string value to EnableBAServerIntegration and set the value to TRUE.
  7. Right-click again in the right-hand side of the Registry Editor and choose New > String Value.
  8. Edit the name of the string value to EnableLegacyBAServerDataExchange and set the value to TRUE.
  9. Close the Registry Editor.
To verify that the change took effect:
  1. Open ArcMap.
  2. Expand the ArcCatalog window.
  3. Expand the Business Analyst Repository node in the ArcCatalog window.
  4. Right-click Default Project.
The following options should now be available: Upload Project, Download Project, as well as the new option: Publish Project.
Article ID: 000015662
Software:
  • ArcGIS Business Analyst Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
