HOW TO
Before you begin, please be aware that the procedure outlined in the following document is not supported. The only supported method of enabling editing on 3D shapefiles is using 3D Analyst extension. The steps below explain how to customize the system script 'View.ToggleEditingUpdate' so that you are able to start editing on PolylineM shapefiles.
Code:
or (clsName = "PolylineM")
Code:
if ((clsName = "Point") or (clsName = "PolyLine") or (clsName = "Polygon") or (clsName = "GeoEvent")) then
Code:
if ((clsName = "Point") or (clsName = "PolyLine") or (clsName = "Polygon") or (clsName = "PolyLineM") or (clsName = "GeoEvent")) then
Start Editing under the Theme menu will now be enabled.
Article ID:000002888
Get help from ArcGIS experts
Download the Esri Support App
