PROBLEM
When trying to complete Exercise 5 of the Editing in ArcMap tutorial, step 4 requires that you type a cluster tolerance value in the Editor Options dialog.
If you are using an Arcview license, this option is disabled.
The Integrate Command requires an ArcEditor or ArcInfo license. The Integrate Command, and the editing options that apply to the use of the Integrate command, are disabled if the ArcMap license is Arcview.
To complete the tutorial exercise or to use the Integrate command, you will need to change your license to ArcEditor or ArcInfo.
Get help from ArcGIS experts
Download the Esri Support App
