PROBLEM
After setting the flow direction with the Set Flow Direction command on the Utility Network Analyst toolbar, the edges are expected to show a flow direction, but they show an indeterminate flow instead.
Note: This article applies to retired ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Indeterminate flow in a network occurs when the flow direction cannot be uniquely determined by the Set Flow Direction command. Indeterminate flow commonly occurs for edges that form part of a loop, or closed circuit.
Indeterminate flow can also occur for an edge whose flow is determined by multiple sources, multiple sinks, or a mixture of sources and sinks in the network. In these cases, the edge has indeterminate flow because one source or sink is driving the flow in one direction through the edge, but another source or sink is driving it in the opposite direction. One example of this is an edge that has a source at both of its ends will have indeterminate flow. Another example can be seen by following the link on the first item of the Related Information section below.
Article ID: 000006593
Get help from ArcGIS experts
Download the Esri Support App
