ERROR
Map services referenced in the Public Safety Common Operation Picture (COP) provided by United States Geological Survey (USGS) have been retired. Because these services are retired, the application cannot find the map service and gives the following error message:
Error: Earthquakes_Shakemaps layer failed to load: Fault code: 500.The configuration files of the Public Safety COP must be updated with the new replacement map services to fix this issue.
The United States Geological Survey (USGS) has retired map services at the following locations:
<operationallayers> <layer type="dynamic" label="Wildfires" imageformat="png8" url="https://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_haz/MapServer" visible="false" visiblelayers="5,6"> <sublayer id="0" popupconfig="popups/PopUp_USGS_NHSS_Floods.xml"/> <sublayer id="3" popupconfig="popups/PopUp_USGS_NHSS_Earthquakes.xml"/> <sublayer id="5" popupconfig="popups/PopUp_USGS_NHSS_Wildfires.xml"/> <sublayer id="6" popupconfig="popups/PopUp_USGS_NHSS_WildfirePerimeters.xml"/> </layer> <layer type="dynamic" label="Flood_Warnings" alpha="0.75" imageformat="png8" url="https://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_weat/MapServer" visible="false" visiblelayers="0"> <sublayer id="0" popupconfig="popups/PopUp_WW.xml" definitionexpression="event = 'FLOOD WARNING'"/> </layer> <layer type="dynamic" label="Flood_Stream_Gauges" imageformat="png8" url="https://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_haz/MapServer" visible="false" visiblelayers="0"> <sublayer id="0" popupconfig="popups/PopUp_USGS_NHSS_Floods.xml"/> <sublayer id="3" popupconfig="popups/PopUp_USGS_NHSS_Earthquakes.xml"/> <sublayer id="5" popupconfig="popups/PopUp_USGS_NHSS_Wildfires.xml"/> <sublayer id="6" popupconfig="popups/PopUp_USGS_NHSS_WildfirePerimeters.xml"/> </layer> <layer type="dynamic" label="Earthquakes_Shakemaps" alpha="0.7" imageformat="png8" url="https://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_shakemaps/MapServer" visible="false"/> <layer type="dynamic" label="Earthquakes" imageformat="png8" url="https://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_haz/MapServer/" visible="false" visiblelayers="3"> <sublayer id="0" popupconfig="popups/PopUp_USGS_NHSS_Floods.xml"/> <sublayer id="3" popupconfig="popups/PopUp_USGS_NHSS_Earthquakes.xml"/> <sublayer id="5" popupconfig="popups/PopUp_USGS_NHSS_Wildfires.xml"/> <sublayer id="6" popupconfig="popups/PopUp_USGS_NHSS_WildfirePerimeters.xml"/> </layer>
<operationallayers> <layer type="feature" label="Wildfires" url="https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/10" visible="true" popupconfig="popups/PopUp_USGS_NHSS_WildfirePerimeters.xml"/> <layer type="feature" label="Wildfires Perimeters" url="https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/11" visible="true" popupconfig="popups/PopUp_USGS_NHSS_Wildfires.xml"/> <layer type="feature" label="Flood_Warnings" alpha="0.75" url="https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/13" visible="true" popupconfig="popups/PopUp_WW.xml" definitionexpression="event = 'FLOOD WARNING'"/> <layer type="feature" label="Flood_Stream_Gauges" url="https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/0" visible="true" popupconfig="popups/PopUp_USGS_NHSS_Floods.xml"/> <layer type="feature" label="Earthquakes_Shakemaps" alpha="0.7" url="https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/4" visible="false"/> <layer type="feature" label="Earthquakes" url="https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/3" visible="true" popupconfig="popups/PopUp_USGS_NHSS_Earthquakes.xml"/>
Article ID: 000012127
Get help from ArcGIS experts
Start chatting now
