BUG
After migrating to ArcGIS 9.2, the drop-down combo box is not displayed when editing a field with a coded value domain through the Editor Attribute dialog box.
The behavior of the Editor Attribute dialog box has changed with respect to the editing of fields with coded value domains at the subtypes level. To understand this behavior, it is important to differentiate between domains specified at the feature class and subtype levels.
Domains specified at the feature class level apply to all features in the feature class, whereas domains applied at the subtype level are specific to that particular subtype.
Prior to ArcGIS Desktop 9.2, given a field with a domain assigned at the feature class level, if the feature had a subtype and no domain was associated at the subtype level for the field, the Editor Attribute dialog box would use the domain for field set at the feature class level. This behavior could cause issues with the Attribute dialog box when multiple features in the feature class were selected.
At ArcGIS 9.2, the Editor Attribute dialog box always honors and uses the field properties at the subtype level, even if another domain is specified at the feature class level. If a domain is specified at the subtype level, the domain is used by the Attribute dialog box. If no domain is specified at the subtype level, the Attribute dialog box does not use a domain.
Article ID:000009206
Get help from ArcGIS experts
Download the Esri Support App
