ERROR
Drone2Map "Invalid client_id Error 400" error
First Published: December 27, 2022
Last Published: December 27, 2022
Error Message
This document is not comprehensive, there may be additional causes for this issue.
When starting Drone2Map 2022.1 or newer using a Named User License from an ArcGIS Enterprise portal, the following error may be returned:
"Invalid client_id Error: 400."
This error is common with authentication issues, however this is not always the case. This article discusses one of the potential causes and a fix for the issue.
This article assumes that the Named User License has already been properly imported into the ArcGIS Enterprise portal and ArcGIS License Manager. If this has not been done, do so before following this workflow.
Cause
The version of ArcGIS Drone2Map is likely not compatible with the license being used.
Solution or Workaround
The ArcGIS Drone2Map license name should correlate with the software version mentioned below:
License nameVersion used
ArcGIS Drone2MapArcGIS Drone2Map 2.3.3. or earlier
ArcGIS Drone2Map StandardArcGIS Drone2Map 2022.1 or later
ArcGIS Drone2Map AdvancedArcGIS Drone2Map 2022.1 or later
For example:
  • If ArcGIS Drone2Map 2.3.3 or earlier is installed, the name of the license should be ArcGIS Drone2Map.
  • If ArcGIS Drone2Map 2022.1 or later is installed, the name of the license should be ArcGIS Drone2Map Standard or ArcGIS Drone2Map Advanced.
If for any reason the desired version of ArcGIS Drone2Map cannot be used due to an incompatible license, the Customer Service Representative for the My Esri organization may need to be contacted.
Article ID: 000028404
Software:
  • ArcGIS Drone2Map
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
