ERROR
Driver Version Mismatch
Error Message
When saving or performing other functions in ArcMap the following error occurs:
"Driver Version Mismatch"
Cause
The Windows Update site can install an older WHQL-certified version of the display drivers than what is on the system, resulting in mismatched file versions.
Solution or Workaround
Upgrade the display driver to the latest version, or remove and reapply the version currently installed.
Workaround
If the error occurs when saving, a temporary workaround is to disable the 'Save thumbnail image with map' option in Map Properties.
1. From the ArcMap File menu, select File > Map Properties.
2. Uncheck the 'Save thumbnail image with map' option.
3. Click OK to exit Map Properties.
Article ID: 000006585
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
