PROBLEM
With ActiveX Connector, you can use DoZoomToFeatures function of Map object to zoom to the features you are interested in. However, this function also limits the Recordset of the active layer to only those records that satisfy the criteria specified in the function.
For example, the code:
Code:
Map.DoZoomToFeatures statelayer,"STATE_NAME","'Oregon','California'"
The WHERE expression passed to the DoZoomToFeatures function acts as a filter for the given Layer. Hence, only those features which satisfy the expression will be included in the Recordset.
Code:
statelayer.Recordset.Filter.WhereExpression = ""
Article ID:000005917
Get help from ArcGIS experts
Download the Esri Support App
