HOW TO
Download PDF items in Portal for ArcGIS using Python
First Published: January 26, 2023
Last Published: April 7, 2023
Summary
The Python script provided below can be used to download PDF items from Portal for ArcGIS.
This script should be run on the local Python IDLE.
Procedure
#IMPORT LIBRARY
from arcgis.gis import GIS
#PARAMETERS
#specify the path to where you want the PDFs to be downloaded
#specify the Portal for ArcGIS URL
#specify the Portal for ArcGIS credentials
path= r"\\path\pdf"
portalurl= 'https://dns.domain.com/portal'
usrname = 'username'
passwd = 'password'
gis=GIS(portalurl,usrname,passwd, verify_cert=False)
#DOWNLOAD PDFS
#search for all PDF items in Portal for ArcGIS
search_results = gis.content.search(query='',item_type='PDF')
#download them to the specified path
for item in search_results:
    item.download(path)
Article ID: 000028595
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
