Frequently asked question
Does the Web ADF for .NET version 9.2 support Microsoft AJAX 1.0?
Answer
To put the answer to this question in the proper perspective, a set of common questions and answers associated with Web ADF for .NET version 9.2 support for Microsoft ASP.NET AJAX 1.0 are listed below:
1. Are the Web ADF 9.2 controls AJAX enabled?
– Yes.
2. Do they use the same framework as Microsoft AJAX 1.0?
– No. The Web ADF 9.2 controls use the Microsoft ASP.NET 2.0 callback framework. Microsoft AJAX 1.0 uses a partial postback framework.
3. Can Web ADF 9.2 be used with Microsoft AJAX 1.0?
- Yes and No.
Yes: AJAX 1.0 and Web ADF 9.2 controls can be used in the same Web application.
No: Web ADF 9.2 controls were not designed to be used within AJAX 1.0 controls, such as an UpdatePanel. Web ADF 9.2 controls were not designed to utilize the partial postback framework. Thus, explicit use of Web ADF 9.2 controls with Microsoft AJAX 1.0 controls and technology is not supported.
4. Do I need Microsoft AJAX 1.0 controls to take advantage of AJAX functionality in a 9.2 Web ADF application?
- No. The Web ADF already utilizes AJAX technology provided by the Microsoft ASP.NET 2.0 callback framework. Microsoft AJAX 1.0 provides the architecture to support controls that were not explicitly designed for AJAX. Since Web ADF 9.2 controls already support AJAX, they do not need Microsoft AJAX 1.0 to operate asynchronously. For example, a Map control does not need to be placed inside of an UpdatePanel because AJAX support for the Map control is already provided. In fact, the Map control can even be viewed as an UpdatePanel itself.
5. Which Web controls should I use with Microsoft AJAX 1.0?
- In general, any Web control that 1) does not provide its own AJAX implementation or 2) explicitly supports Microsoft AJAX 1.0. The Web ADF 9.2 controls do not fit either of these requirements.
Article ID:000009591
Software:
  • ArcGIS Server
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
