Frequently asked question
Does ArcInfo 7.x and/or 8.0.x need to be uninstalled before you install ArcGIS 8.1?
Answer
Yes, when you install ArcGIS 8.1, you will be prompted to remove any previous versions of ArcInfo workstation. This is because you cannot have two different versions of ArcInfo workstation on the same machine.
You may also manually uninstall any previous version of ArcInfo by using the Add/Remove Programs from the Control Panel. Make sure to remove any installed extensions before removing the core software.
If you have installed ArcView 8.1 or ArcEditor 8.1, you can reinstall a previous version of ArcInfo workstation, but be aware that you will not be able to load any raster data into ArcView 8.1 or ArcEditor 8.1.
Article ID:000004062
Software:
  • Legacy Products
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
