Frequently asked question
Does ArcGIS Online require a Certificate of Authority from a known authority provider?
First Published: June 2, 2016
No, it is not required to use a certificate of authority (CA). Users may use a self-signed certificate, however this is only advised for test environments. Use a CA once ArcGIS Online is deployed in a production environment.
Using a self-signed certificate in a production environment may cause the following issues to occur:
• Warning messages notifying the user is trying to access an untrusted site in ArcGIS for Desktop and web browsers
• Printing from hosted services and accessing the portal from client applications may result in unexpected behavior
• The inability to open a federated service in the portal map viewer, add a secured service item to the portal, login to ArcGIS Server Manager on a federated service, and connect to the portal from Esri Maps for Office
Esri Maps for Office is able to sign in if the self-signed certificate is installed into the Trusted Root Certification Authorities certificate store on the machine running the Esri Maps for Office.
Article ID: 000013275
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
