PROBLEM
Displaying data in web applications fails with error code 103900
First Published: August 18, 2017
When attempting to display data in a web application, for example Web AppBuilder for ArcGIS, and printing the map using the Print widget, the print results fail to display any data and return a Layer Drawing Error. The following example shows how the error may appear in the ArcGIS Server Manager log:
Image of typical error in the ArcGIS Server Manager Error log
In the raw log file located in the folder, C:\arcgisserver\logs\<User>\server, the error may appear as follows:
Error:
<Msg time='2014-12-10T10:56:34,672' type='SEVERE' code='103800' target='servicename.MapServer' methodName='DrawGraphicCursor.NextGraphic' machine='abc' process='32624' thread='30964' user='anonymous' >There is an error during the draw abc (1.) Out of server memory [scheme,(2.) layername].</Msg>
Cause
There are two possible causes for the drawing error:
  • A syntax error in the query request. If a syntax error is present, the error presents itself as the first sample error in the ArcGIS Server Manager logs.
  • The ArcGIS Server machine experienced a resources issue.
Solution or Workaround
Use one of the following options to solve this issue:
  • Ensure the correct syntax and schemas are used for the query request.
  • Identify and remove any corrupted Esri resources. For more information, refer to the following web help document: ArcGIS Server: Analyze your GIS resource.
Article ID: 000016601
Software:
  • Web Applications
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
