HOW TO
Display .DBF tables containing null values in ArcGIS
Summary
To display .DBF tables that contain null values, the table needs to be properly formatted first. Instructions provided describe how to properly format first .DBF tables.
Procedure
It is important that table names and field names do not contain spaces, do not have numeric leading characters, and do not use foreign characters other than the underscore.
  1. Import the .DBF file into Access and 'Save Table As' an .MDB file.
  2. Using ArcCatalog, create a new personal geodatabase and right-click on the personal geodatabase and select Import > Table.
  3. Select the .MDB file as the Input Table.
  4. Specify a name for the Output Table Name. Click OK.
    The table displays in ArcCatalog, and it is able to display the null fields.
Article ID: 000008037
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
