HOW TO
Display coverage node errors in ArcMap
Summary
Core ArcMap functionality doesn't allow the display of dangling or pseudo
nodes in a coverage. This article provides code and instructions to add this capability to ArcMap.
Procedure
  1. Build the coverage for nodes in ArcCatalog.
    A. Open ArcCatalog and navigate to the coverage.
    B. Right-click on the coverage and select Properties.
    C. Click the General tab.
    D. Click the Build button.
    E. Select Node from the Feature class dropdown list and click OK.
  2. Open ArcMap and add the Editor toolbar.
    Click View > Toolbars and select Editor.
  3. Add the coverage to ArcMap, start editing, and set the target layer to the arc feature class.
  4. Open the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  5. In the Visual Basic Editor, select Tools > References and check 'ESRI Arc Automation Server' and 'ESRIutil Automation Server'.
    These references are for ODE components. These options will not be available if you did not install ODE when you installed Workstation ArcInfo.
  6. In the Visual Basic Project Explorer Window expand Project > ArcMap Objects, right-click and select View Code to open the code module.
    [O-Image] Visual Basic Project  Explorer
  7. Paste the following into the code module.
    Public Sub CreateDangleElements()
    On Error GoTo eH
    'Get the editor extension
    Dim pEditor As IEditor
    Dim pID As New UID
    pID.Value = "esriCore.Editor"
    Set pEditor = Application.FindExtensionByCLSID(pID)
    'Make sure you are editing
    If Not pEditor.EditState = esriStateEditing Then Exit Sub
    'Coverage workspace only
    If Not TypeOf pEditor.EditWorkspace Is IArcInfoWorkspace Then Exit Sub
    'Get the target layer
    Dim pEditLayers As IEditLayers
    Dim pTarget As IFeatureLayer
    Set pEditLayers = pEditor
    Set pTarget = pEditLayers.CurrentLayer
    'Make sure it is a coverage arc featureclass
    If Not TypeOf pTarget.FeatureClass Is ICoverageFeatureClass Then Exit Sub
    Dim pCovClass As ICoverageFeatureClass
    Set pCovClass = pTarget.FeatureClass
    'Make sure the target is an arc feature class
    If Not pCovClass.FeatureClassType = esriCFCTArc Then Exit Sub
    'Need the full coverage path as a string for the node errors command
    Dim sCoverageName As String
    sCoverageName = pTarget.FeatureClass.FeatureDataset.Workspace.PathName _
    & "\" & pTarget.FeatureClass.FeatureDataset.Name
    'Use the ARC ODE component and run the NODEERRORS command
    Dim pArc As New ESRI.Arc
    Dim pResults As New ESRIutil.Strings
    Dim lSev As Long
    lSev = pArc.Command("nodeerrors " & sCoverageName & " dangles fullreport", pResults)
    Dim i As Integer
    If Not pResults.Count > 2 Then
    MsgBox "No Dangles Found.", vbInformation
    Exit Sub
    End If
    'Get the graphics container
    Dim pAv As IActiveView, pGC As IGraphicsContainer
    Set pAv = pEditor.Map
    Set pGC = pAv.GraphicsContainer
    'Set up Status bar objects
    Dim lNum As Long
    Dim dInt As Double
    Dim pSbar As IStatusBar, pPro As IStepProgressor
    Dim Start, Finish, TotalTime
    lNum = pResults.Count - 1
    dInt = lNum / 100
    Set pSbar = Application.StatusBar
    Set pPro = pSbar.ProgressBar
    pPro.MinRange = 1
    pPro.MaxRange = lNum
    pPro.StepValue = dInt
    Dim pPt As IPoint
    Dim pElem As IElement
    'Loop through the strings results collection and pull out the coordinates
    'then create a new point geometry and add that point as a marker element
    'to the map
    For i = 0 To pResults.Count - 2
    Dim sBefore As String, sAfter As String, sCoord As String
    sAfter = After(pResults.Item(i), "(")
    sBefore = Before(sAfter, ")")
    sCoord = sBefore
    If Not IsNumeric(Before(sCoord, ",")) Then Exit For
    Dim dX As Double, dY As Double
    dX = CDbl(Before(sCoord, ","))
    dY = CDbl(After(sCoord, ","))
    Set pPt = New esriCore.Point
    pPt.PutCoords dX, dY
    Set pElem = New MarkerElement
    pElem.Geometry = pPt
    pGC.AddElement pElem, 0
    pPro.position = i
    pPro.Message = "Adding Elements..."
    pPro.Step
    Set pElem = Nothing
    Set pPt = Nothing
    Next i
    pPro.Hide
    pAv.Refresh
    Set pResults = Nothing
    Set pArc = Nothing
    Set pAv = Nothing
    Set pGC = Nothing
    Set pPt = Nothing
    Set pElem = Nothing
    Exit Sub
    eH:
    MsgBox "CreateDangleElements failed: " & Err.Description
    End Sub
    Public Sub CreatePseudoElements()
    On Error GoTo eH
    Dim pID As New UID
    Dim lSev As Long
    lSev = pArc.Command("nodeerrors " & sCoverageName & " pseudos fullreport", pResults)
    Dim i As Integer
    If Not pResults.Count > 1 Then
    MsgBox "No Pseudos Found.", vbInformation
    Exit Sub
    End If
    Dim lNum As Long
    Dim dInt As Double
    dInt = lNum / 100
    pPro.MinRange = 1
    Dim pPt As IPoint
    'to the map
    For i = 0 To pResults.Count - 1
    sCoord = sBefore
    Dim pMarkerElem As IMarkerElement
    Set pMarkerElem = pElem
    Dim pSimpleMark As ISimpleMarkerSymbol
    Set pSimpleMark = New esriCore.SimpleMarkerSymbol
    Dim pRgb As IRgbColor
    Set pRgb = New esriCore.RgbColor
    pRgb.Blue = 255
    pRgb.Red = 0
    pRgb.Green = 0
    pSimpleMark.Color = pRgb
    pSimpleMark.Style = esriSMSDiamond
    pMarkerElem.Symbol = pSimpleMark
    pPro.position = i
    If Not pPro.MaxRange = i + 1 Then
    pPro.Step
    End If
    Set pElem = Nothing
    Set pPt = Nothing
    Next i
    pPro.Hide
    pAv.Refresh
    Set pArc = Nothing
    Set pAv = Nothing
    Set pGC = Nothing
    Set pPt = Nothing
    Set pElem = Nothing
    Exit Sub
    eH:
    End Sub
    Private Function Before(Str As String, SearchStr As String) As String
    ' Returns the substring of Str to the left of the leftmost
    ' occurrence of the searchStr.
    Dim position As Integer
    Dim length As Integer
    position = InStr(Str, SearchStr)
    length = Len(SearchStr)
    If Not (position = 0) Then
    Before = Mid(Str, 1, position - 1)
    End If
    End Function
    Private Function After(Str As String, SearchStr As String) As String
    ' Returns the substring of Str to the right of the leftmost
    After = Mid(Str, position + length)
    End If
    End Function
  8. Run the CreateDangleElements routine or the CreatePseudoElements routine to create graphic marker elements at the location of the dangle or pseudo node.
    In ArcMap, click Tools > Macros > Macros.
Article ID:000002989
Software:
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
