HOW TO
Use the following Oracle SQL syntax to discover user sessions that are holding state locks, which prevent the compress operation from moving the DEFAULT version to state 0 (the base state).
Upon connecting to an enterprise geodatabase with ArcGIS, a state_lock is obtained for the state the connection references. The state_lock is used to ensure the state of the versioned geodatabase that the session is reading is not deleted or compressed.
When state_locks are present, the compress operation cannot compress those states with state_locks. In some specific cases, because of the state_locks, the compress operation will not be able to compress the SDE.DEFAULT version to state 0 (the base state).
The following SQL statement can be executed in Oracle to discover what user sessions hold state_locks that are preventing the compress operation from compressing the DEFAULT version to state 0.
With this information, the geodatabase administrator can contact the user and request that they disconnect or use brute force and end their session with the sdemon -o kill command or by ending their Oracle connection.
Code: SELECT DISTINCT d.sde_id, d.owner, TO_CHAR(start_time, 'HH:MI:SS MON-DD-YYYY') LOGON_TIME FROM sde.state_lineages a, (SELECT state_id, lineage_name FROM sde.states WHERE state_id = (SELECT state_id FROM sde.versions WHERE owner = 'SDE' AND name = 'DEFAULT')) b, sde.state_locks c, sde.process_information d WHERE a.lineage_id <= b.state_id AND a.lineage_name = b.lineage_name AND c.state_id = a.lineage_id AND c.sde_id = d.sde_id ORDER BY d.sde_id ASC; SDE_ID OWNER LOGON_TIME ---------- ------------------------------ --------------------- 304 JOHN 09:47:47 OCT-08-2009
Article ID: 000010761
Get help from ArcGIS experts
Download the Esri Support App
