HOW TO
Discover all tables and views in an Oracle instance which have a st_geometry attribute
Summary
Instructions provided describe how to discover all tables or views in an Oracle instance which have a st_geometry attribute with the given SQL syntax.
It may become necessary to know which schemas have tables or views containing a st_geometry attribute in the case where the SDE schema must be dropped. If the SDE schema is removed prior to removing the st_geometry attribute from existing tables, once the SDE schema has been dropped (thus the removal of the st_geometry type), the tables may no longer be accessible.
Procedure
To list all tables or views in an Oracle instance that have an st_geometry attribute execute the following SQL statement in SQL*Plus as a user who has access to the view DBA_TAB_COLUMNS.
Code:
SELECT owner, table_name, column_name
FROM dba_tab_columns
WHERE data_type_owner = 'SDE'
ORDER BY owner, table_name;
    Article ID: 000010845
    Software:
    • Legacy Products
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
