PROBLEM
DGN (design) files created in MicroStation v8 do not draw in ArcMap
First Published: May 5, 2016
DGN files added to ArcMap from MicroStation version 8i do not display in ArcMap.
Cause
The DGN files must be compressed in MicroStation version 8i before the features display properly in ArcMap.
Solution or Workaround
Use the MicroStation version 8i command 'Compress Design'.
Contact the manufacturer, Bentley Systems, for further technical assistance with MicroStation products.
  • In Microstation, click File > Compress > Design. After compressing the file, save the file again. The compressed file draws properly in ArcMap, and converts to geodatabase using the CAD to Geodatabase tool in ArcToolbox.
Article ID: 000008269
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
