HOW TO
Determine if ArcGIS server services are public or internal-facing in Collector for ArcGIS from an iOS or Android device
First Published: May 5, 2016
Last Published: April 26, 2020
Summary
The instructions provided describe how to determine whether an ArcGIS Server service is public or internal-facing in Collector for ArcGIS. Only public-facing services can be accessed over a cellular network in Collector for ArcGIS.
The following scenarios occur if internal-facing services are accessed over a cellular network.
Procedure
  • For iOS using a cellular network
    1. Open Collector for ArcGIS on an iOS device.
    2. Click on a web map. An error occurs.
    If an internal-facing service is accessed over a cellular network on an iOS device and error occurs when trying to open the web map in Collector. The error states: "Layer Not Loaded, unable to layer 'Name of Service'. A server with the specified hostname could not be found."
    [O-Image]
  • For Android using a cellular network
    1. Open Collector for ArcGIS on an Android device.
    2. Click on a web map. Data does not display.
    If an internal-facing service is accessed over a cellular network on an Android device, no error message are returned. However, no layers are loaded in the web map. When the layers are viewed they are inactive ('grayed out').
    [O-Image]
Article ID: 000012698
Software:
  • ArcGIS Collector
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
